If Formula Not Right - help!
I am struggling here! I thought I was getting better - but I need help. Thank you in advance!
My column is "Sourcing Manager" and I am trying to create another column with a formula to add their email automatically.
If the Sourcing Manager is "Monique", then it should list Monique@theroomblocksource.com
If the Sourcing Manager is "Karen", then it should list karen@theroomblocksource.com
If the Sourcing Manager any other name, then it should list hello@theroomblocksource.com
This is the formula I am trying:
IF({Sourcing Manager}=Monque, monique@theroomblocksource.com, IF({Sourcing Manager} = Karen, karen@theroomblocksource.com, hello@theroomblocksource.com))
Best answer by Sho
The missing "String" is the problem.
IF( {Sourcing Manager}="Monque", "monique@theroomblocksource.com", IF({Sourcing Manager} = "Karen", "karen@theroomblocksource.com", "hello@theroomblocksource.com" ) )
SWITCH function is much easier
SWITCH({Sourcing Manager}, "Monque", "monique@theroomblocksource.com", "Karen", "karen@theroomblocksource.com", "hello@theroomblocksource.com" )
Forum|alt.badge.img+24
  • July 28, 2023
  • July 28, 2023
Perfect, thank you @Sho !! That worked!
