Is it possible to remove spacing between words using formula
  • Apr 15, 2020 3:42 PM UTC
  • 265 views
is it possible to remove spacing between words using formula
Best answer by kuovonne
Do you want to remove all spaces, or only some?
You can replace the space character with an empty string using the SUBSTITUTE function. It is documented in the formula field reference.
SUBSTITUTE({field name}, " ", "")
  • Apr 15, 2020 3:56 PM UTC
  • Apr 15, 2020 3:59 PM UTC
Thank you Kuovonne it worked perfectly :heart_eyes:
