Little help on changing field type within a formula column
  • Jul 16, 2019 4:04 PM UTC
  • 57 views
Hy Guys,
We’re trying to do a formula in order to create a new graph within our dahsboard. However it keeps telling us that:
=> Y-axis field “Pourcentage_retard” is not numeric
The formula that we’re using is:
=> IF(nb_intervention=0, “0”, inter_retard/nb_intervention)
I’m wondering if a need to add a formula to switch to numeric.
Thanks in advance!
Best answer by Yan_de_Paula
is inter_retard/nb_intervention a single field or two?
  1. You need to add {} around field names.
  2. I do NOT know if a slash is allowed in field names. (I bet it is.)
  3. if inter_retard is text (not a field name), it should be “inter_retard”&{nb_intervention}
    Good luck!
Hello ! Thanks for your help. Actually I found it. I put a string around 0 => “0”. By taking of it, now it’s ok.
IF(nb_intervention>0,inter_retard/nb_intervention,0)
Cheers.
  • Jul 16, 2019 4:16 PM UTC
    Good luck!
  • Jul 18, 2019 9:51 AM UTC
    Good luck!
Cheers.
