Need help with an IF statement
  • October 25, 2020
  • 104 views
I’m new writting formulas, I’ve read all the guides on airtable’s website and other posts in the forum.
However I can’t get my formula to work. I only need that when the value of a cell is equal to a number a specific name appears.
This is what I’ve wrote; IF (Total = “6.99”, Hernia discal, BLANK())
But airtable won’t let me keep the formula because it’s misspelled.
Any advises?
Thanks.
Anything that isn’t a function or the name of a field needs to be in either straight apostrophes or quotation marks. If a field name contains a space it must be surrounded by curly braces.
So your formula should likely be either:
   Total = "6.99",
   "Hernia discal",
   BLANK()
or
   Total = "6.99",
   {Hernia discal},
   BLANK()
Kamille_Parks11
Forum|alt.badge.img+27
   Total = "6.99",
   "Hernia discal",
   BLANK()
or
   Total = "6.99",
   {Hernia discal},
   BLANK()
Thanks a lot for your fast reply, It worked.
What if I want to add different values for total? I’ve tried to duplicate the formula with different values but it doesn’t work,
Something like this:
Total = “6.99”,
“Hernia discal”,
BLANK()
Total = “10.99”,
“Hernia discal lumbar”,
BLANK()
Total = “15.99”,
“Hernia discal cervical”,
BLANK()
Thanks a lot for your help.
Kamille_Parks11
Total = “6.99”,
“Hernia discal”,
BLANK()
Total = “10.99”,
BLANK()
Total = “15.99”,
BLANK()
If you’re comparing the value of one thing multiple times you could use a SWITCH statement.
SWITCH(
   Total,
   "6.99",
   "Hernia discal",
   "10.99",
   "Hernia discal lumbar",
   "15.99",
   "Hernia discal cervical",
   BLANK()
For your reference, if you wanted to nest an IF() statement it would look like this:
   Total = "6.99",
   "Hernia discal",
      Total = "10.99",
         Total = "15.99",
         BLANK()
Thanks mate, you’re a beast.
