Need help with if formula with multiple options
  • September 16, 2022
  • 58 views
I need quite help with a formula. Currently, my formula is as follows which says If FIELD A = “Hubspot Invoice”, then use Field B to populate cell, otherwise use field C.
currently, my formula is IF({FIELD A)}=“HubSpot Invoice”, {FIELD B}, {FIELD C)})
however, I’d like it to say if “FIELD A = HUBSPOT INVOICE” OR FIELD A = “ZOHO INVOICE”, Field B to populate cell, otherwise use field C.
How do i capture the two conditions in the If field?
Forum|alt.badge.img+16
Hi @Sahil_Mehta,
This should do it for you
IF(OR(A='HUBSPOT INVOICE',A='ZOHO INVOICE'),B,C)
Be careful of the text case, in one example you have Upper case and in another you have Lower case. If the options are a drop down, enter them exactly as they are in the drop down.
