Problem calculating percent of survey responses when no answer given
Forum|alt.badge.img+7
Hi everyone!
I’m new to learning how to use the deeper aspects of Airtable and how to use linked records.
The problem I’m having … I have a multi-question survey, and am trying to calculate the percentage that people answered a question “yes”. However, some people skipped the question, so I need to remove these from the % calculation.
My goal is to determine what percentage of responses were “yes” from those who actually responded.
I tried by making a lookup table for each question that would only show answers yes/no (so no blank answers), and then the formula COUNTALL ({my lookup field name}) to first tell me how many responded, but I am not getting the correct answer.
Does anyone have recommendations for how to solve this?
Thank you
I
Best answer by Mohamed_Swella1
Thank you for the quick reply @Mohamed_Swellam! I appreciate it…
I had tried the COUNTA as well… the answer was not correct for some reason. I just says “1”… I am attaching screenshots… This is when I was doing it with a formula.
I then tried to use a Rollup on the new table and I was able to get the correct summary (thank you!). But I’m curious if this is what you meant to do? Is there a way to use the rollup without a lookup field? When I tried to do that in my original table, I could not select the field in the same table.
Here’s what I initially tried (incorrect):
Here’s using a rollup, but how can I do in my main table?
Hi Rob,
This make much more sense now :slightly_smiling_face:
Actually since the Yes and No are linked records in the survey table, you can just make a Count field which will count all the linked records.
The formula field is basically counting the number of cells/field, which in your case is one :slightly_smiling_face: In the rollup field its counting the number of records that has a yes / no.
You do not need a lookup field, you need a linked field to use the rollup.
Mohamed_Swella1
hi @Rob_Jameson ,
Welcome to Airtable Community !
With the little data I have, I think what you are looking for is COUNTA() not COUNTALL()
COUNTA counts the cells that has value, COUNTALL counts all cells even if blank.
Mohamed_Swella1
hi @Rob_Jameson ,
HOWEVER, since you are using a Lookup field, this means there are linked records. Why not use a Rollup field instead?
  • August 11, 2022
Mohamed_Swella1
Hi Rob,
  • August 11, 2022
Hi Rob,
Fantastic… you have taught me much… Thank you @Mohamed_Swellam!
Mohamed_Swella1
You’re welcome Rob, my pleasure !
