Regex in Airtable is so frustrating. Help with string.
  • Jan 18, 2023 1:06 PM UTC
  • 182 views
Forum|alt.badge.img+7
I wish Airtable Regular expressions followed some common flavours so we could test it with regex101.com
I can make it work in these builders, but then when it comes back to Airtble #ERRROR. It's a huge potential but otherwise Airtable makes it hard to figure out why it isn't working.
I am trying to pull out the Patient's name from a Text extract. It always occurs after "Patient's name: " & before "Birthdate:"
Example string:
Radiology Report Patient’s name: Barney (57493) Birthdate: 7/5/2013
One Regex101.com, and regextester.com I can get it perfectly with this regex:
(?<=name: )(.*)(?= Birthdate: )
But when I put that in airtable:
REGEX_EXTRACT({PDF Text Extraction}, "/(?<=name: )(.*)(?= Birthdate: )")
I get a big fat #ERROR
I know it's me but can anyone point me int he direction of a regex tester that is compatible with Airtable?
Or tell me what I can use here?
Matthew_Lanni
This should do the trick, I think: REGEX_EXTRACT({PDF Text Extraction}, "Patient's name: (.*?) Birthdate:")
As for testing, I find that Google Sheets gives far better error messages and uses the same syntax (as far as I've seen), so that's what I use to figure it out before putting it into Airtable.
  • Jan 18, 2023 1:55 PM UTC
Airtable REGEX formula functions are based on Google's RE2 library, which does not support the before/after features you are trying to use, among other things. It is the same library that Google Sheets uses.
If you stick to "simpler" regex expressions you should be okay.
  • Apr 6, 2023 2:10 PM UTC
Something as simple as this fails in Airtable:
REGEX_MATCH('123','/^\\d{3}$/')
very frustrating indeed
