Replace multi-select values using formula
  • Jul 12, 2019 4:11 PM UTC
  • 95 views
I am looking for a way to use the REPLACE() formula function to replace values in a Multi-select column with different values on a new column.
For example:
The original column contains column Type of question with multi-select values bug-report, enhancement.
Can we create a new column called Type of question (new) with the corresponding new values: bug-report-new and enhancement-new?
I would use the SUBSTITUTE() function instead: SUBSTITUTE({Type of Question},'bug-report','bug-report-new')
^ This simple formula will work, but you’ll have to nest a bunch of SUBSTITUTE()s to account for each multi-select option possible.
So try something like this: IF({Type of Question},SUBSTITUTE({Type of Question},',','-new,')&'-new')
^ that formula will add a ‘-new’ to the end of any field option you have., which is handy if you have quite a few or will need to add more options in the future since this formula will account for new options automatically/
Kamille_Parks11
Forum|alt.badge.img+27
  • Jul 13, 2019 2:41 AM UTC
^ This simple formula will work, but you’ll have to nest a bunch of SUBSTITUTE() s to account for each multi-select option possible.
This format helped, thank you! I ended up nesting the formula for my replacements. :white_check_mark:
