Automating Task-Project Link on Project Management Interface
  • November 14, 2024
  • 2 views
JBJ
Forum|alt.badge.img+14
  • 36 replies
Hi guys,
For each of my clients, I create a project management interface where they can keep track of the project's progress. One of the pages on this interface is a list of tasks.
As of now, I have to manually link each newly created task to the proper project. So I would like to automate this process.
Ideally, I would have liked to set up an automation chose trigger would have been 'when a new record is created on this interface'. But this trigger doesn't exist.
So the only workaround I found for now is to create a List view with hierarchy on and to show the Project name on the level above. But I feel it adds unnecessary clutter to the page design since clients of course only want to see the tasks related to their project.
I assume I'm not the first one to have this need. So do you guys any other workaround to suggest?
Thanks for your help.
Dimitris_Goudis
Hey @JBJ
This makes sense! Would you mind to have the Project's details page and there a list of associated tasks? In that case you can display the associated tasks and have a button to trigger an automation (create task) or button to new task creation form
JBJ
  • 36 replies
  • December 4, 2024
Dimitris_Goudis wrote:
Hey @JBJ
Hey @Dimitris_Goudis,
Thanks for suggesting this solution. I decided to settle for the List view with both hierarchy and editing inline on because I favor simplicity. It felt to me the easiest way to see your tasks and add a new one.
Take care.
