Data visibility to read-only collaborators
  • February 22, 2024
  • 85 views
JM1234
Is it possible to show specific data which is unique to Interface-only viewers. I want to create an interface where they can see a record of form submissions (use case: invoices) which they have submitted via an airtable interface form and see what the current status is without seeing everyone elses response.
Is this possible? if so, how do I go about it?
I would like to avoid duplicating and re-making interfaces for individual viewers so am looking at softr worst case.
Dan_Montoya
  • Employee
  • February 22, 2024
Use an interface filter that selects records based on their user email (or user if you prefer).
JM1234
  • February 22, 2024
Excellent news! Thank you so much for the quick reply.
If you need to provide access to external clients that don't have an Airtable seat, you could look at using Noloco and building an app that your team and clients can log into. You can setup different permissions to show each user only their data
Mariam_Ispiryan
Forum|alt.badge.img+8
Hi, wanted to let you know that, at Softr we now have Global Data Restrictions, which will make it possible to show specific data to Interface-only viewers.
You can learn more about it here: https://docs.softr.io/user-management/pxnkp9H3qyEVMF6XUceqnj/global-data-restrictions/3kH6DuUvRNVztnGzAJoiL8
