Try using the "Group by" dropdown:
Gives me this:
Based on this:
Gives me this:
Based on this:
Is it possible to create a stacked line chart in the interface based on several fields/columns from the same table in a base?
I created a stacked line chart using Vega-Lite in the dashboard in the base, but I would like to do the same in the interface. Additionally, Vega-Lite is not interactive, so I cannot see the exact values when I hover over the lines/data points.
Heh to deal with this I usually create another table that compiles all of the data from those fields into a single field with a single select to differentiate each field.  I then group by that single select, thus creating the stacked line chart
Not the most elegant, but it works!
Hi Adam,
Thank you so much! I tried it out and it works. You're a lifesaver!
