Interface designer - allow users to create records button missing
Hello !
this might sound strange but I'm encoutering issues while wanting to allow users to edit or add new records to a list view in an interface.
Sometimes the toggle button to allow this just doesnt exist ... this is quite frustrating and I haven't figured out the way out of this.
Please help 🙂
See screenshot
Hey!
Please note that you can either click on the group holding the list view (as done on the image attached on your question), or on the list view itself. See differences below, paying attention to the section with blue borders (on click).
At Group level, you would click on the title of the group for example -see image below: You can toggle on "Add records through a form", which will show the button on the top right corner of the group, to create a new record.
At a list view you would click on the actual list -see image below: You can toggle on "Add/delete records inline", which will  show the small "add campaign" button (format similar to text actually) below the last record on the list (only record is Campaign XYZ on this example).
I believe this should solve the issue!
  • 13 replies
  • August 13, 2024
Mike_AutomaticN wrote:
Hey!
Hello Mike thanks for responding
I've noted the group vs. list view. But still i don't have the same user actions possibilities to toggle. I only have the option ''Click into record details'' available. Please see screenshot.
Is there any general interface setting that i need to update ?
  • 13 replies
  • August 15, 2024
Hello !
anyone can please help with that ?
  • 13 replies
  • August 15, 2024
I've tried to duplicate the interface / the page / the block but there's nothing to do, the toggle button allowing to create new records in line or edit them is missing 😞
Hey! Please DM me, and I’ll try to help you out 💪
