Hello - I'm fairly new to Airtable and I have a base with 5 tables, each table contains the schedule of a different project that I am tracking. I want to create an interface calendar that displays milestones across the 5 projects, but I can only see how to source from one table.
Is there a way to connect your interface to more than one table? Thank you in advance for any help!
Link interface to more than one tab
Best answer by DisraeliGears01
Short answer is you can build an interface page that spans multiple tables using the Blank page option. It'll take a bit more construction than a simple calendar page, and your tables will be contained on different calendar widgets, but it'll all be the same interface page.
If getting all the project info on to one calendar widget is the goal, you can either restructure your data so there's one project table, with each row being a project interlinked to other tables (better for long term data structure anyway probably) or you can create a junction table and use lookup fields to get all your necessary info into one table to use for an interface.
