Management Insights Dashboard in Project Management Interface not filtering
I used the PM Template as a guide to build out a PM base and interface, copying all data exactly as shown. The only issue I'm having is that when you select Assignee, only the first pie chart updates to reflect the Assignee selected. The rest of the widgets do not update. I have both open (the template, and my version) and when I toggle an owner in the Template, those widgets update, but mine does not, Again, I copied everything exactly as shown in the Template so this really shouldn't be happening. Any ideas?
Could you provide a readonly link to an example base?  It's hard to troubleshoot what might be wrong without direct access to how you've set it up I'm afraid
  • May 30, 2025
I had to double-check that all linked records in the synced tables actually existed and matched my filters—turns out some were blankI had a similar issue and found that sometimes the filters work oddly if your linked records aren’t synced right or if blank fields aren’t handled. I ended up using a PowerPoint timeline maker to visualize the project phases instead, since it was quicker for leadership views and didn’t depend on Airtable’s filters acting up. It’s a decent workaround till they fix the dashboard filter behavior. or not properly linked, messing up the filtering.
