Missing nested records option in interface
  • September 14, 2024
  • 6 replies
  • 401 views
Jakub_Szerszen
Forum|alt.badge.img+7
Hi guys!
I'm wondering if I'm doing something wrong or something has recently changed?
Long story short, I'm not able any longer to nest the records through the interface.
Currently, I'm working on the new base and I wanted to nest records to organise them in some logical order.
For example, if I look at one of the bases I already created, you can see the option to nest the records.
Now, I'd like repeat the same process in another base and the option to nest the records is missing?
Any idea if something has changed?
It seems to be in the second page of the level setup.  Try hitting "Next":
You should then get the option:
Forum|alt.badge.img+31
Pascal_Gallais-
@Jakub_Szerszen , @TheTimeSavingCo
I have a naive question: what is a nested record?
Thank you
Pascal
Jakub_Szerszen
Thank you
Pascal
thanks @TheTimeSavingCo much appreciate your help!
@Pascal_Gallais-  Nested records let you to manage records in the hierarchical order within the same table.
For example, you have a list of tasks  in one of your tables in the grid view these tasks would look as follow:
The list view let you to organise them in the hierarchical order and if you enable the nested records (remember that you'll need to have a linked record type field within the same table. E.G. the subtasks on the screenshot above), these records will look as follow:
Pascal_Gallais-
Thanks @Jakub_Szerszen
That's very clear and very interesting
Regards,
Pascal
  • December 16, 2024
Adding on with a related question. Is it possible to have a nested view like this in an interface, in addition to this view in the base?
Hmm, could you elaborate?  We're able to create nested List views in the Interface now, so I think I don't understand your question, sorry!
