SHARABLE RECORD VIEW MOBILE PROBLEM
  • November 19, 2025
  • 90 views
I was having a problem to share record view for just one record in my airtable. Then I just shared all recordview to my external users. Now because they are opening my shareable view from mobile apps they can not see the right side of the recordview. How can I solve my problem ? I am open to any suggestions. Recrod View is not necessary but I just need to be able to share my record to external users to fill some places in my record (Not creating record, updateing record)
If they need to update the record I’d highly recommend you ask them to download the Airtable app.  Airtable expects users on mobile devices to be using their app and accessing Airtable via the browser on a mobile device doesn’t work that well
If that’s not possible then I’d suggest trying a List Layout instead maybe?  You could also try doing a shared view with a Fillout form too
https://support.airtable.com/docs/using-the-view-share-menu-in-airtable
​@FarukBera
The easiest & simplest & quickest way to do this is to use Fillout’s advanced forms for Airtable, because it lets your customers view and/or edit an existing record by giving them a unique URL for any record.
You can even create a login page to add security to your form.
Fillout is 100% free, and it offers hundreds of features that Airtable’s native forms don’t offer, including the ability to update Airtable records using a form, create custom PDF files from a form submission, accept payments on forms, pre-fetch dynamic data from an Airtable record, customize the style and branding of your form, customize a theme for your form, display Airtable lookup fields on forms, create new linked records on a form, add a login page to your form, perform math or other live calculations on your forms, collect signatures on a form, create multi-page forms with conditional paths, connect a single form to dozens of external apps simultaneously, add CAPTCHAs to your form, and much more.
