Help needed to connect Airtable to Power BI / Excel
Hi Everyone,
I am using Airtable as my CRM. I love it. However, the data vizualisation blocks are not enough and I would like to create comprehensive dashboards in Excel or Power BI.
I am not a technical guy but I managed to connect the API for small tables.
However, my 2 main tables have 25k and 8k rows… I do not know how to do it for these ones.
I would like to have my data updated daily so I can share it with partaners.
Is the API allow this task ? Anyone can help ?
Thanks a lot,
Hugo Le Morvan
  • 366 replies
  • August 8, 2018
Hi Hugo,
What are the issues you are running into?
FYI: My clients are using a custom made web service connecting up to 100 separate Airtable bases (all synchronized fast and perfectly). The amount of data should not be a problem. :slightly_smiling_face:
Feel free to contact me with a private message!
Best,
Arthur.
  • 351 replies
  • August 8, 2018
Hey Hugo, we too can help here. Very familiar with the API as well as working with PowerBI.
Ping me at dan@openside.com
A bit late possibly? But here is how you can have it automatically imported into excel:
Hello @Hugo_Le_Morvan !
I recommend checking data integration tools that can help you move data from Airtable to Excel or Google Sheets. There are a bunch of data integration tools or ETL tools that can help, such as Coupler.io.
