Add Linked Field by Barcode
  • July 19, 2019
  • 53 views
Hey, I would love to be add entries to a linked field by scanning barcodes with a mobile device. This would be a great way to implement inventory or attendance tracking quickly and easily. This would require adding a “barcode” search option to the linked records popup.
Kamille_Parks11
Forum|alt.badge.img+27
I agree completely. It would also be helpful for event managers to track participants, or anyone who uses Airtable as a check-in/check-out system. Name badges or key cards can have a barcode on them, and if we can link records using a barcode scanner it would make the process run smoothly.
  • July 19, 2019
Yes. Exactly what I would like to use it for. I want to track attendance with QR codes on name tags. A doorman would be responsible for scanning the tag as attendants enter. I would keep a table with each event as a date, and then add the attendants via linked record field.
Forum|alt.badge.img+15
  • August 22, 2020
We’ve built a barcode scanner (or QR code) that allows you to create new records by scanning barcodes. The scanned values of these created records could be a linked field.
