Add records from org chart block
  • August 20, 2018
  • 14 views
I’m building out an org chart - it has around 50 rows. I find i’m often jumping between the block view and the table to ad the right rows. It would save time if there was some way to add child (or parent) record from the org view. For example, there could be a + symbol to the bottom tight of reach box.
