It would be great if we had the ability to use the record coloring feature to flag records that satisfy any number of criteria based on any number of existing table fields, and to allow multiple color “flags” per record. I would love to be able to see, at a glance, when a record satisfies multiple criteria, but not have to create a really complicated formula field to accomplish the same goal.
Add the ability to color records using multiple colors
