Allow option for automation loop to ignore script errors.
  • Feb 11, 2025 7:16 PM UTC
  • 61 views
JeffJohnVol
Forum|alt.badge.img+16
If this exists and I'm not aware of it, apologies in advance.
When looping through data from a view in an automation, I execute a script inside the "Repeat for each..." sometimes I get some bad data fed in and it causes the whole automation to fail.  I'm frequently adjusting the script to account for the data, and making steps to improve the data coming in, however it would be nice if I had the option for it to continue on ("Ignore error") and let me know after the fact so the other 99% of the data that was good can continue to process and I can resolve the data issue later.
Alternatively, if there was the ability to execute a different step if there is an error, that would be even more grand.
Thanks.
Kenneth_Raghuna
Forum|alt.badge.img+20
Hey Jeff,
If your script has been properly written to handle errors, it should still allow the script to finish, and the repeating actions group to continue.
Here are two good resources to read up on regarding error handling:
https://dev.to/accreditly/mastering-error-handling-in-javascript-3ice
https://medium.com/@JavaScript-World/tips-for-efficient-error-handling-in-javascript-boost-your-codes-reliability-2d6824aec6d8
JeffJohnVol
  • Feb 12, 2025 3:12 AM UTC
True, and if airtable workflow was properly designed it would have error handling built in like make.com and all other mainstream workflows do.
Most of the data issues I am able to catch, and it would be nice to exit the script with an error code so it can trigger an alternate path (if such a system existed on the platform, which is part of my suggestion).
Kenneth_Raghuna
Hey Jeff,
My apologies I did not notice that this was logged under "Product Ideas," I thought this was an ask for help with getting an automation to run when errors come up.
I definitely agree that there should be some more robust error handling options built into the platform itself.
JeffJohnVol
  • Feb 12, 2025 7:40 PM UTC
LOL, no worries.  I appreciate the follow up statement. 🙂
