Change Hour Scale in Calendar View
  • February 15, 2023
  • 7 replies
  • 86 views
What is the proposed idea/solution?
When looking at a calendar in Week, 3 Day, or Day view, it would be great to change the hour scale — that is, make an hour larger in the view.
How does is solve the user problems?
When scheduling lots of records in a very small timescale (<15 minutes) things can get very cluttered, and it feels like we're not using the screen real estate to its fullest extent. Being able to zoom in on the Y-axis would fix this problem.
If anyone has a solution for how to view records on a smaller time scale (right now I bounce between a table and a calendar), that would be greatly appreciated.
  • April 7, 2023
This is desperately needed for things like conference or event planning and seems like it would be so obvious.
  • December 15, 2023
I really need this feature too. I wish calendars didn't start at zero hour. The majority of my programming starts around 8am. Adjustments to the time increments would also allow for better visualization of the data.
  • April 7, 2024
Would love this too! Just made an app for scheduling shifts of our workers. No one starts at 00:00, earliest at 08:00... still calendar always shows half empty. Make a diff start/end hour or zoom out time scale, anything would work! Thx
ziggypac
  • September 3, 2024
Yes! Being able to adjust either not showing hours before/after a certain time, or simply defaulting the view to start at a specific time would be very helpful!
  • December 4, 2024
We are experiencing the same problem. We make schedules available on our website and since the calendar starts at 12 p.m., people see the calendar empty when they scroll down the screen 1 a.m to 7 a.m.) We would like the calendar to be able to display from a specific time, like 8 a.m.
  • December 16, 2024
This is needed incredibly badly and would put airtable above and beyond many calendar applications with this simple change. It would also make the calendar view much more useful if we had even just a "start time within day" and a "duration" as that would also help for event/operations spaces where you may not start until noon, and then will run events until 2am. Right now, we're stuck using a google sheet to do this unless we want to invest in YET ANOTHER app and waste time syncing it to airtable. It's crazy that in the year 2024 we still don't have such a basic and straightforward feature.
  • January 24, 2025
Yes please fix this as soon as possible!!!
