Copy Field Text Using Airtable Button
  • July 26, 2020
  • 76 views
Forum|alt.badge.img+12
Hello!
I very often go info my bases to copy 2/3 fields from a much larger base - It would be great to be able to use buttons to copy information from selected fields to the user’s clipboard to avoid unnecessary navigation.
Here’s an example of what that might look like:
https://jsfiddle.net/jfriend00/v9g1x0o6/
And a code logic example I was able to find during research:
stackoverflow.com
Click button copy to clipboard using jQuery
jquery, html, css
Forum|alt.badge.img+8
  • December 2, 2021
same issue. I need some way of copying lots of text without having to scrape drag
Karlstens
Forum|alt.badge.img+24
  • December 14, 2021
Having an Airtable Button to copy field text would be extremely useful. This definitely gets my vote! Also, it would be amazing if Buttons could have their own field/text/emoji icons on a per record basis (which could be referenced/changed via Scripting App/Automation Script too)
Forum|alt.badge.img+10
  • June 18, 2024
I would just add that such a button could be made as an optional feature in field options.
In addition, in interfaces you could go further and make a click (on the actual text) to copy field option.
