Differentiating between blank and zero
  • February 15, 2017
  • 6 replies
  • 81 views
It would be great if there were a way for a formula to differentiate between blank and 0 in a number field. Currently, cellname = "" and cellname = 0 both return true, whether the value is "" or 0.
I understand why this would be the default. It’s like truthy operators in JS (false == 0). But it would be useful if there were an option to circumvent that default behavior, and do a more strict comparison in a particular formula.
Potentially cell = BLANK() would return true for a blank value, but not for a zero value. Currently, equality comparison with BLANK() also returns true for 0.
Alternatively, it could be done with a new function - something like STRICTEQUALS(a, b).
Forum|alt.badge.img+12
  • February 16, 2017
For now, you can use COUNTA(cell) which returns 1 when a cell is non-blank (including zero) and 0 if it’s blank.
We may in the future consider adding an IS_BLANK() function since, as you pointed out, cell = BLANK() isn’t always equivalent and the COUNTA workaround isn’t very obvious.
  • February 16, 2017
Thanks, glad to know there’s a way to do it already.
  • March 13, 2017
Thanks! I needed this workaround tonight.
Oli_Steadman
Forum|alt.badge.img+16
That’s a lifesaving workaround
  • September 15, 2020
Thank you! This is exactly what I needed!
  • July 4, 2022
I also stumbled across this issue. Especially because Field != Blank() always returns true. I don’t think that Blank() should be used, as it is error-prone. Could you please introduce the Is_Blank() function?
