Dynamic and Static Automation Choices
  • July 21, 2023
  • 16 views
blaclair
What is the proposed idea/solution?
When you link a field to a Record ID in the Automations some of the Fields let you toggle between static and dynamic some don't. I feel like this should be an option for all fields. That way all fields can be updated with.
How does is solve the user problems?
When a form is submitted to update a record with some fields not offering that option it updates the WHOLE record. Not just the fields on the form.
How was this validated?
I tried the automation... Some fields have static and dynamic options and others do not.
Who is the target audience?
Anyone who sets up a form to update a specific record in another table.
