FR: Offline mode
Show first post
  • September 12, 2016
Hi Howie,
Thanks so much for taking the time to explain these obstacles in more detail. One solution comes to mind, but of course it has drawbacks like any other solution. I wonder if this might be a potential solution…
While still connected, a user may intentionally request (via toggle switch) to put a specific base in offline mode. In response to this request, the server notes the UserName and UTC timestamp of the request, sends a response back to the user’s device and the device makes a local copy and goes offline.
While offline, the user’s device prohibits structure changes to the base, such as addition or deletion of tables and fields, editing field types, formulas, relationship types, etc while offline. When the user requests to go back online, the device sends a copy of the base to the server, the server compares each table to existing tables and informs the user if any changes conflict with other user changes and if conflicts cannot be resolved via the timestamp and normal rules, then the server offers to export a summary of conflicts in the form of a common text file format (csv for example) containing the table names, record names and list of conflicts. The device should also include a warning message when the user makes the request to go offline, that offline usage carries some risks that incompatible changes could be made by other users while the device is offline and if that happens, a clean merge could become impossible when device goes back online. The user must acknowledge and accept the terms in order to enter offline mode. Maybe the base owner would also receive a copy of the request, or maybe just a summary of the conflicts, or none.
By making offline mode an intentional request, with a warning, and with specific limits, I think this would greatly decrease the chances of conflicts and offer a manual solution when conflicts did arise. If the offline user was not the base owner, maybe the base owner should receive the copy of the conflicts and decide what to do with them. Maybe the base owner could also accept / reject the requests to go offline. Or maybe the base owner just delegates users who are allowed to use offline mode, without further approvals. All just ideas that would definitely need fine tuning.
One last twist to this is that maybe other collaborators with edit rights can see a visual indicator when some users are working offline and popup a warning message if attempts are made to change structural and functional parts of the base, besides merely adding, deleting and editing data.
Thoughts?
Hi Joshua, this is one (valid) proposal amongst a permutative spectrum of design possibilities. This particular approach is not too far off, directionally, from some of our internal explorations. As with any other possibility, though, it comes with its own set of advantages and disadvantages. For instance, it would be quite tedious to manually resolve conflicts. (I’ve personally experienced this pain as an Evernote user; conflicted notes/notebooks appear quite frequently in my usage of that product and require a frustrating amount of extra work to resolve.) Requiring an explicit toggle for offline mode may not help in situations where the internet disappears unexpectedly, or when one forgets to hit the switch ahead of time (i.e. you’re boarding a long flight, and neglect to make the change). In any case, even if the offline client does not allow structural changes, the same class of merge conflicts will arise if other online clients do perform structural changes during that time.
While we appreciate the suggestions for technical implementation, at this point the most useful thing to inform the design is to receive detailed, specific usage stories directly from as many users as possible. With those data points, we can better assemble the various technical mechanisms at our disposal into a cohesive experience that delivers the best set of tradeoffs, where best is informed by our users.
How would you want to use Airtable offline?
I travel and I collect music. My main database is on my collection and I do need to check the database abroad, in the odd cellar and other strange places to avoid bying the same album more than twice. :winking_face:
Do you use Airtable alone, or with collaborators?
So far I’ve used my data alone, but I do see how I can share this with people who’s looking for a gift to give me.
How much do you need to be able to do in Airtable while offline?
Create and edit records. I do not need to change the database as such.
How tolerant would you be of having to resolve merge conflicts manually?
Somewhat … Conflicts should be presented in a clear and understandable manner and with a simple way of resolving those conflicts.
Would you primarily be using offline mode on desktop or mobile?
Offline mode on mobile only is more than acceptable. One can always find a Starbucks for other uses.
One last note; What I do need most is access to my data, anywhere, at anytime on any device. The last is important; when I travel I use Android & Chromebook, at home I use all the iStuff, PCs and Linux depending on where I’m at. But I do need to be able to have at least read access.
I would be glad to have Airtable offline available exclusively on the read-only mode. It would solve some of the problems above, I guess.
Not for profit providing services to seniors to help them remain in their homes.
Contractors and volunteers need to enter visit data. Ideally, much of this would
be pull down selections both from pick lists, i.e. service provided and selection
of actual data, i.e. client name. When client name is entered it would be good
to populate contact information like phone and address.
Currently alone but planning for future collaboration.
Mostly add service data but to do so may require client identification.
In this case conflict management could be tolerated to a small degree, but since remote
data entry is being done by contractors and volunteers the level of technical expertise is minimal.
Typically the only type of management that might work is if they attempt to enter the same service record more than once.
Primarily mobile, but I suppose since we have a very mixed technology case
it could be either.
  • October 13, 2016
Option to set the initial tables as single user upon creation? I like the form / structure / views of airtable as a database as a tool. if your not worried about collaboration and maybe just sharing read only views . That might be an option.
Forum|alt.badge.img+14
  • October 25, 2016
Offline mode is difficult. Merge conflicts WILL occur for sure. But Please consider implementing a read-only offline access first. It will not result in any merge conflict but will be extremely useful. Think of it like printing off a document and take the paper version with you onto a plane.
As for how much data to cache? That should be easy to work out based on user browsing history. Show an “unavailable” sign for anything not cached.
I believe some offline data is better than no offline data at all. At the moment all my data is unreadable during a flight or on high speed rail trains!
Having read-only access off-line would work perfectly for me. Think about creating a database of 1001 travel sites with associated restaurants and attractions (like a book). This could be built prior to travel and viewed on a laptop or phone at any location. It would be necessary to place the database in read-only mode while connected, which would be fine. Edits along the way could be added when reconnected to wifi.
  • November 15, 2016
The First Tee of Greater Richmond uses Airtable to track student progress in our programs. Right now, we coaches use our own data to connect to Airtable on our mobile devices when we need to record information out on the golf course. If mobile data coverage is an issue out on the course, we are forced to write things down and perform data entry when we’re back in the clubhouse.
Also, coaches without a mobile device and mobile data plan must write everything down and record it later. It would be great to give them a WiFi-only iPad to use while coaching.
With collaborators.
Ideally, everything we can do online other than modify table structure.
Honestly, not very tolerant. Our coaches have varying degrees of technical sophistication.
Exclusively mobile.
  • November 16, 2016
Just a read only access for the existing database is huge for most people. it will be super helpful to quick search on the database even without internet connection!
I want to use Airtable as a small, easy-to-use database tool for personal and small business use, whether online or offline. That, I thought from your marketing/branding, was the whole point of the app. I don’t want a Filemaker, I want a Bento. So all your worry about all these multiple users potentially making changes at exactly the same time that might mess up the database doesn’t make sense to me; that sounds like an enterprise app problem. I think you need to make up your mind what market you are targeting. As far as how I want to use it offline, I want to be able to make a few changes while I’m flying, either on the OS X app on my MacBook Air or on the IOS app on my iPad, when I’m up in the air with no internet access, and have them automatically sync next time I connect with wifi or cellular. Or maybe I’m out on my boat for the weekend, same thing. Or maybe I’m in a client’s office or the audience at a symposium and I’m having trouble getting the wifi password; there are many different scenarios where I temporarily can’t connect. I’m not looking to do huge amounts of work offline.
Right now mostly alone, although I anticipate collaborating with a small handful of, say, 1-5 people.
Would like it to be fully functional.
That would be time-consuming (time-wasting), so not very tolerant.
Both.
I’ve been searching around for a goo, easy-to-use simple database program. Started playing around with HanDbase but don’t like the complicated syncing methodology, so thought I’d look for something better. Your product is getting good reviews, and looks good to me, and the syncing problem is non-existent, as long as I’m online. The inability to work offline is a deal-breaker. May have to deal with the hassle of HanDbase syncing, at least I can work offline.
I am using Airtable in Africa. Internet connections are not stable. Dificult to be used when connections are interrupted. An offline modus could possibly prevent data loss and resume syncing when online again. Would be a very helpful feature, whcih would enable us to use the product on a much larger scale!
I would really appreciate an offline/sync feature.
E.g. if you planned your trip at home using Airtable and in the foreign country you do not always have internet access but would like to see what you planned.
Maybe a checkbox for each base which will allow offline/sync until the next WLAN Hotspot is available.
Read only as a 1st version will be cool.
But add/update of data for existing bases should also be possible.
Regards,
Stefan
  • December 24, 2016
Thank you for asking !!
Teacher/coach/artistic director,mo have a database of exercises and data about projects and evolution.
I (very) often work in places with not coverage, and one wifi.
I see much more a database as being based on my device and backed up on the net (+possibility to sing with my other devices).
I use it alone.
I had Bento and iDatabase, but they stop supporting their apps :frowning:
(Bento is a good example as the sync was between my MacBook and the I devices, without an online backup. IDatabase offered the possibility to backup (and also sync) with Dropbox) would you consider that as a possibility?
I would say: make it fully operational offline, so to have full autonomy is using the database. And the online connection is a bonus to backup and sync.
I would literally need it to be that way in order to be able to use it.
I can’t really answer this one for now.
I find your online facilities to be VERY USEFUL and answering my personal need of a database :slightly_smiling_face: )
So the real thing that I miss is the full offline use.
Thank you so much !
Ami
Exclusively mobile.
  • December 30, 2016
I use AirTable for work editing a magazine. When working on an aeroplane or in a foreign country, I want to access a contact database and publishing schedule. Otherwise, I use Workflowy for less structured information, which works well offline.
Do you use Airtable alone, or with collaborators? Alone
How much do you need to be able to do in Airtable while offline? Read only would be better than nothing. Otherwise editing and adding records. I wouldn’t need to make any structural changes.
I like manual.
Would you primarily be using offline mode on desktop or mobile? Desktop on the plane, but mobile in the taxi.
Just started to use Airtable yesterday and found this app just fantastic… until I realized it is not usable offline. This is unfortunately a show stopper for me.
I travel a lot around the world for work and wanted to use Airtable as a resource center for many info I need to have on hand all the time.
Unfortunately in my case roaming cost can quickly become a huge hurdle…
Same here. Potentially great app let down by lack of offline access to data. E.G. myself and my partner have a holidays base with places we want to visit, etc. But it’s utterly useless if I’m out in a foreign country and have no data or roaming costs a fortune.
  • January 9, 2017
I would like to use Airtable to save and manage all my data connected to different topics (work, ihome, personal …) It’s important to access my data offline on mobile (Android).
View my data is fundamental, but editing is very important - if I see something or I have an idea, or have to work on someting on the go.
If I have the opportunity to select the right version.
Would you primarily be using offline mode on desktop or mobile? primarly on mobile
  • January 9, 2017
I live and work in the Blue Ridge Mountains, giving computer tech support. My main concern is about offline access for my iPhone. Verizon coverage is the best in the region, but in many locations I can’t get an LTE or 3G connection, and in some locations there’s just no signal. This problem is universal among professional service people in the region. I normally avoid any phone app that stops working when the signal isn’t good enough.
Right now I’m learning Airtable and I use it alone, but soon I’d like to collaborate with my business partner, and may hire employees and have them use it later.
Read-only would be way better than having no offline access. Ability to edit while offline would be a plus.
For how long do you need to be able to use Airtable offline?
Generally up to 8 hours on my cell phone, till I return to my home office and use my computer to get a larger view.
No problem – for me that would be much better than losing access to Airtable. I don’t mind following instructions to compensate for less-than-stellar user features. For me Airtable is an excellent construction kit and already beautiful. I don’t need perfect versatility, just predictable access online and offline.
Primarily mobile. However, in stormy weather out her in the country, homes and businesses sometimes lose Internet service altogether, so offline access for desktop and laptop computers would also be appreciated.
How would I want to use Airtable offline?
Let me explain. I used Bento on my iphone, still do actually, but I was introduced to Airtable just last week by my daughter who knew I was looking for a replacement for Bento. Airtable looked just the thing I was looking for until today when I tried to use it in the wild. I was in a bookshop in the outskirts of Glasgow and wanted to add a book to my booklist. I go the message “connecting …”. Then I noticed I had no network access. What use is it having a portable database that is only portable if you have an internet connection. I had to resort to Bento again. It’s clumsy and awkward and now doesn’t sync but it works on my phone.
In Scotland we have very poor public internet access. Sometimes we get 4G, but only really in city centres. If you’re lucky, 3G elsewhere. I’d like to see the app buffer the data and allow it to sync with the home station when access is available and when it detects that changes have been made.
Alone
About an hour max at a time should see me through the changes/additiions I would need to make.
That wouldn’t be a great problem for me. I’m used to fixing data stuff given enough instruction.
Primarily mobile. Thankfully we have good internet access at home.
PS
I’d just like to add that this is the most sophisticated forum reply form I’ve use. Quite excellent!
How fabulous - an app company that allows users a voice.
I work in film. The problem occurs when out of internet range and I need to access and add information.
Alone is my preference.
I would need to be able to add or subtract data information. I would not necessarily require the ability to make structural changes.
This would depend on the degree of ‘manual’. If it was something that required little skill, or a skill that could be learned with ease - I would have no issues, in light of having the ability to work offline.
I consider the online feature as a way to backup. Therefore, I would tend to work as much as I could in this mode.
  • January 25, 2017
Thanks, AirTable and Howie for taking the time to explain the issues being explored and listen to needed uses.
I work for an international nonprofit where we visit many sites that have no internet. We would need to have someone use it offline for at least a few hours up to a day or two. Most offline cases would be intentional and foreseen but there is poor internet connection in other places, so there would be many times when the connection would be interrupted.
I would collaborate with 4-10 other users.
I would need to add records, ideally using a form, as well as read/edit, and add tasks. I would not need to do and restructuring of the base.
This would depend on the complexity. I would be open to this if it were simple, especially if the offline use was noted explicitly so I knew what was coming.
Mobile.
I’m also curious, can you help me understand how much data Airtable uses, now if a user is editing offline?
Thanks.
This is a must have feature!
Yes, Offline Mode please!! I use databases to store gps waypoints, notes, images and all kinds of information about outdoor locations (many of which are outside of cell coverage) and although I love Airtable, in it’s present form it can’t be used for any data gathering outside of cell coverage. This would be greatly beneficial to outdoor enthusiasts, travelers, surveyors, disaster relief, restoration, construction, forestry, you name it- any type of activity that takes a person outside of cell coverage.
Here is one idea on how to accomplish this…
-User would have an “Offline” switch and the app would warn the user the device will download a full copy of the database to the local device which can be read, edited, etc but no table structures or relationships may be edited in offline mode. Only records can be read, edited and added in offline mode but table, form and field types are locked while offline.
-When connectivity is re-established, an integrity check would be done to ensure that the table structures and relationships have not changed (by other users that were online) since the user went offline. If architecture has changed, user is presented with a choice to either make a copy of the device data with the prefix “syncconflict_” or ask the user if they want local device data replaced with the current server structure and data.
In any case, I really hope Airtable implements an Offline Mode as soon as possible. It would make this app so much more userful for so many types of businesses, organizations and activities that do not necessary have data coverage 100% of the time.
While I have applications where offline field data collection, as described, is critical, those are currently in Filemaker using Tim’s FM EasySync to sync the collection when returning to wifi.
The current application in development on air table requires a much more modest off line use.
When volunteers are providing a service to a client they need to enter data.
Currently if they open the form while online, and keep the page open they can use pick lists but not linked selections. They also cannot submit the data, and certainly cannot enter another, or more services before coming back to internet connectivity. Some can do this with mobile connectivity but it is not available in all locations.
  • February 7, 2017
I am also very interested in offline mode
  • February 9, 2017
Offline vs what exists now is a matter of increasing the allowed latency.
So I’m curious - if one of the potential un-resolvable conflict situations arises with the current setup - what happens? And how often does it actually happen?
Going a step further, how often are users actually engaging in behavior that would lead to such conflicts were they offline? (if you were to log and analyze data from current use in order to determine such a thing)
  • February 15, 2017
+1 for offline support to serve as trello replacement. Thank you!
