Unless I misunderstood your request, wouldn’t your problem be solved if Airtable let mobile users link fields using the barcode scanner instead of only allowing typing? Its still a feature request but a far easier thing to implement.
Yes, that would work for the specific use case, although more generally I think a generic VLOOKUP formula could be used in other ways. For example, I’ve got single select field and the values in the select are also in a reference table. If I select “Whatever” from the select, another attribute in the ref table is populated for me. I could see this being useful where the first input field is barcode, single line text, single select, date, maybe others too.
JB
            I really would love this tool as well. It would make our lives so much easier!
            Anyone know if this was ever solved? I’m also interested in this function as I have a use where;
We provide items for the homes we manage. i.e. Toielt paper, paper towels, kitchen spices, etc.
We are looking to purchase all items in bulk to have in our warehouse so that they can be readily available for when needed at a home. Each property has it’s own P&L so it’s important that we retroactively allocate the cost of each item to the property so it’s recorded.
If we could use the scan barcode function to simply scan the barcode for the item being pulled, let’s say toilet paper, and then the remaining fields are auto-populated with the appropriate information.
Example: I am in the warehouse and I am needing to pull one toilet paper, two paper towel, and some soap; I simply scan the bin’s barcode and the record fills in the cost/item name/etc.
Is this doable?
            I agree with the request - my Base has a number of lookups that are inherently more complicated because of the forced creation of Linked Fields. Being able to perform something similar to a Vlookup would be much easier, especially considering that my Base is basically a migration from a complex Excel spreadsheet that was nothing but Vlookups and other formulas.
