Organizing Saved Views
  • June 13, 2017
  • 64 replies
  • 219 views
Good morning,
I am wondering if there is a feature which can allow us to organize our views? What I mean is I have made a number of views and I would like to organize them like a page tree. For example:
Most used
-view
-view
-view
Leadership Views
-view
-view
-view
You can see this list is getting long… it would be great to bucket them and be able to collapse them when not needed?
  • June 13, 2017
As my list of ‘Views’ evolves, I am finding it frustrating that there is no way for a view to inherit the changes I make in another view.
I would find it very helpful to create views in a hierarchy so that changes are inherited by the child view, but omitted (hidden) in the parent, if created in the child view… something like this:
  • June 13, 2017
Ooh, very interesting
  • June 14, 2017
Thanks @Hashim_Warren. Would be helpful right!
Field Width, Field Order, Field Visibility… would be enough, I’d suggest.
Filter settings might be a step too far. What do you think?
Can’t be too hard to implement, can it?
  • June 16, 2017
I think this would be amazing, I similarly have views that would greatly benefit from being able to inherit from the parent. Every time I insert a column it stinks to have to go through every single view and move that column from the very end over to where I want it, and then adjust the width again, and so on and so forth. Even if there was an option when creating a new column or something to “perpetuate across all views” would be great. Or “apple to the following views” selections even.
  • June 17, 2017
One issue to solve is reminding users that a change on THIS view will affect THAT view. It has to be elegant and obvious.
Any ideas?
  • June 19, 2017
There is plenty of room in that title bar to add a little bit of detail…
Maybe some sort of a breadcrumb path to indicate your position on the hierarchy could help:
Forum|alt.badge.img+16
  • March 7, 2018
I definitely support this.
I’ve just counted. I have 70 views in one of my tables. The implementation of view search was a life saver but still. I do have many views that are used to trigger zaps. I have to prefix them with “DO NOT edit” to avoid any user to mess with the filters and screw up the zaps and all that derives from that. I also have a group of some 20 views that are shared with individuals as read only and my users tend to use them and change the filters, messing with the read-only people ability to see the data.
I’d be great if they could be grouped so that it was clear those views are to be left alone, or group by purpose or whatever. It seems that it could be easier than setting view-level permissions :slightly_smiling_face: But anyway view organization is probably more useful for more users than view-level permissions.
Would love to see this happen.
  • September 5, 2018
Just to be able to organize and create groups of views within one organization to make it easier to browse the views
  • September 5, 2018
Same thing for blocks!
  • October 1, 2018
I would very much like this feature as well. We have one base with over 50 views have to rely on search to find them. This makes onboarding new people much harder than it should be. A folder system for views would be amazing.
  • October 3, 2018
Hello community/developers,
I’ll begin by saying I love this product. My colleagues love this product. We’re now beginning a journey to hopefully migrate our business away from Excel and into Airtable and I can’t wait to have our data in a cloud environment with an simple and easy to use API.
Unfortunately, this means that our flagship application (the venerable sales log) is being looked at by more eyes, from more angles and that means more views! Too many views if you ask me, but I am but a humble in-house developer.
I would love it I could somehow organise the views drop-down into logical categories or groups, to make browsing for the easier. I know there’s a search field (indeed, there’s a search field just about everywhere you could possibly want one) which is great for me, but some users prefer to see a finite set of options before them so they can find their way there.
tl;dr: I would like to organise the views drop-down into collapsible groups.
Forum|alt.badge.img+12
  • October 4, 2018
I would like that too!
Also i would like to be able to add certain people to a view. Like you have personal view for only you it be great to have group view for teams that only they can edit.
  • June 3, 2019
I 2nd this, great idea!! I have some tables with 30-40 views in them, it would be soooo helpful to be able to organize them in folders or be able to group them in some sort of collapsible view.
  • July 19, 2019
+1 for this. The ability to group the views would be the next thing I’d like to see in the UI. E.g. a group to put all the zapier views that are used for automation.
Forum|alt.badge.img+8
  • August 13, 2019
+1 for this. This would save a great deal of time and prevent a great deal of confusion for our use-cases, too.
+1 for being able to group views or have folders, etc. One of the things I use airtable for is price lists. I would like to be able to group customers in the same level together, along with many other groupings. Love the product! Keep up the good work.
+1
We need folder views for different initiatives and/or teams working out of the same base
:heavy_plus_sign: :one: for a method to group saved views.
  • November 19, 2019
+1
This would make life much easier for tables with many views, and would encourage people to follow good base design and combine multiple similar tables into views of one table. Currently, following this design can result in a completely unwieldy number of views.
  • February 28, 2020
:heavy_plus_sign: :heavy_plus_sign: :heavy_plus_sign:
This would be IMMENSELY helpful. Please implement this.
Yes please!
It would be even better if we could create editable pages, like Microsoft Access Forms, in which we could position links to views anywhere on the form. This would allow us to group our views any way we want.
I would have one page dedicated to Admin Views and several other pages dedicated to Data Entry Personnell Views. Depending on which project a data entry person is doing, they may need to access a select handful of views, and so it would be great to give us this flexibility to group views onto pages as we see fit…
+1 I think it’s very helpful for all.
Forum|alt.badge.img+11
  • March 3, 2020
+1 for this!!!
This is a FANTASTIC idea. Sitting here just thinking about all the time that this feature would have saved me.
  • March 3, 2020
+1 for this too. As we all go deeper into our integrations, we naturally need more views and a nicer way to manage them :slightly_smiling_face:
Airtable I love you.
2 years later and we are still waiting on this one. The people have spoken.
I am a new user less than 60 days and already see this as a huge need.
please, thank you. rock on.
