The ability to add a description for view colors
  • September 1, 2022
  • 23 views
When colors are used to highlight records based on conditions it’s often hard to remember what each color means. It is especially hard when the users work with multiple bases where the same colors are used for different conditions.
It would be great to have a description per color configuration in each view and display it by hovering over the color label.
  • September 1, 2022
That’s a good idea! One possible solution for you might be to create a base description (now called “base guide”), which you can get to by clicking on the name of your base in the upper left of the screen.
Forum|alt.badge.img+10
  • September 2, 2022
This is great. We currently use shared views that show a legend for color schemes in other tables. +1
