Way to remove views quickly or in bulk
  • October 24, 2018
  • 37 views
Forum|alt.badge.img+14
We create a lot of views in our Airtable to share with clients, but all these views have to be deleted after a while. It’s a long list of views, and manually deleting each one is a very long and inconvenient process.
Instead of going through the whole views list, clicking a view, deleting it, and doing that over and over – isn’t there any way to do this in bulk, or just quicker?
I’ve checked the API docs and find nothing on handling views, so I’m afraid I’m out of luck there too?
Anyone got any ideas?
Forum|alt.badge.img+11
View Management and best practices are of interest to me. It would be nice to hear how others are managing a large amount of views.
The only advice I have for others is a naming convention for all of your views then using the Find a view to find the view you are looking for…
Forum|alt.badge.img+15
  • July 5, 2020
Another option is not to have lots of views in the first place. If you have many clients that you need to share Airtable views with, it would be better to use a third-party software that allows you to have some kind of a client portal. Which is something that we have built.
