Wider view/expanding view in Expanded Record View
  • January 6, 2021
  • 20 views
Forum|alt.badge.img+12
The expanded record view uses only a small portion of the screen, even on biz size laptop is only half the screen. For long text boxes (which we use a lot of) this really reduces the editability/readability of fields with a lot of content. Can the restraints on that Expanded data box have an override arrow that fits to screen? I know you can expand long text boxes from within the grid view to a slightly better size, but you are not really in the record card view, and is still not great. Thanks!
  • January 14, 2021
Some examples of how this limits use/cuts off drop down field etc, even on a laptop screen there is screen real-estate to be had:
