Airtable extension to trigger incoming webhook automation
  • Sep 7, 2023 1:52 AM UTC
  • 103 views
I am building a custom extension which will send data from Airtable to a third party API (the user will provide their API key to this API). This third party API will then send updates to the base, which will update a given record. I cannot find any solid example of how to create a custom extension that can update a base async (this API runs twice a day) rather than when a button is clicked or another action performed by the user. I know I can use an Automation to trigger the response to the incoming webhook, but I want it to all be bundled within the extension. Is there no way to do this without having the extension and automation separate?
  • Sep 7, 2023 7:01 AM UTC
A custom extension cannot accept incoming webhooks. A custom extension also only run when its dashboard is open.
Are you building this just for yourself or do you want to turn this into a product?
Can you set up your third party service to use the Airtable web API to update the base, instead of an incoming webhook?
Forum|alt.badge.img+11
It would be better to use google apps script, you can publish web apps that respond to get and post requests and also create scripts that run on a schedule.
