Any option for dynamic fields showing up depending on input?
Forum|alt.badge.img+8
Without using forms, but within AirTable itself, is there any option to build anything like a flow chart, where selecting different options would show different fields to input data?
For example let's assume I have an employees table. Each employee can either be employed directly or via a subcontractor - for each option I need to fill out different fields, and then for each one of them they can be in different departments, and for each department I want different fields filled out once again and so on.
Is there any way to do that?
Best answer by Yaron_Avramov
Thanks, I've actually found a solution to the problem. It's awkward but it works:
https://community.airtable.com/t5/formulas/show-hide-field-based-on-condition/m-p/167879#M19986
Thanks @OfficeOurs
Databaser
  • 866 replies
  • November 12, 2023
Not natively no. You could use automations and/or record templates to fill in standard data per option.
  • 7 replies
  • November 12, 2023
Thanks @OfficeOurs
Forum|alt.badge.img+33
  • 8860 replies
  • November 12, 2023
Yes, it’s disappointing that Airtable doesn’t offer this natively yet (except on forms).
Although one thing to note is that there are now 2 external apps available for Airtable that offer this feature natively: Fillout and Noloco.
I give a brief tutorial of Noloco on this episode of the BuiltOnAir podcast. And I also presented a full one-hour webinar on Noloco called Building a Client Portal on Noloco powered by Airtable.
And I give a brief demo of Fillout on this episode of the BuiltOnAir Podcast.
