We’re brand new to Airtable, so hope I’m framing this question correctly.
Is there a way to have a Long Text field in multiple tables that you can change in one table and it will update automatically in all of the others?
I know you can do that by creating multiple views of a table, but we’re looking for a way, as an example to take a “notes” field in one table and add it to a new table in the same base that has totally different fields.
Thanks in advance for any help you can be.
