Creating a pivot table for conversion tracking with custom fields and formulas
  • December 17, 2024
  • 3 views
Hi there,
We are attempting to create some sort of conversion tracking tool for our leads. The fields in our data table that are relevant for this are: Account Type (Lead, Customer, Rejected), and Source.
There doesn't appear to be a way we can easily create a table, like in Excel, where we can simply name columns and create formulas in each cell.
Here's the table we're attempting to recreate:
 The issue we're running into is we can't create the majority of the columns seen in this screenshot. Any ideas to help?
Try converting your Source field into a linked field to a new table, then use rollups and lookups to get the data you want:
Link to base
Dimitris_Goudis
Hey @snowsurance
You can create a formula field and perform your calculations, and using Interfaces, you can easily create pivot tables. Did you try these features?
- Formula tutorial
- Interface dashboard
Please do not hesitate to reach out for any support 🙂
Thanks
Dimitris Goudis
Forum|alt.badge.img+28
Link to base
  • December 17, 2024
Dimitris_Goudis wrote:
Hey @snowsurance
- Formula tutorial
Thanks
Dimitris Goudis
Thank you, Dimitris!
I appreciate you pointing me in the right direction.
  • December 17, 2024
Link to base
Thank you very much, Adam!
That's exactly the solution I was looking for. We greatly appreciate the help.
JeffreyW
  • December 30, 2024
Thanks, this post helped me too. The approach is working
