Cross-Base Lookup Function & Linking Cells Between Sheets in Airtable
I am working with two separate bases in Airtable and would like to use a Lookup field to retrieve data from a table in another base. Is there a native way to achieve this without relying on third-party integrations?
Additionally, I need to link a specific cell from one table in a base to another table in a different base. Is there a built-in Airtable feature that allows this?
I would appreciate any insights or best practices from those who have worked with similar requirements.
  • March 28, 2025
You can sync the table that you are looking up from to the other base using the built in sync feature.
Hey ​@Ebenezar!
You will want to take a look at this support article from Airtable. Their documentation is not always great, but they did a great job with this one.
