Cross Tab features
  • October 10, 2018
  • 44 views
Good Morning:
Is it possible to do a type of Cross tab table in Airtable? I have a table that currently has the names of the Team in a field and the areas of specialization across the top. I would like to flip it so that the employee name is actually disbursed across columns as field headers. If not then I will just redo it. It’s only about 20 records, but if there is an easier way to do this, I’d rather do that.
Thanks
Julie
Can you explain your base structure? I think that maybe you are using Airtable incorrectly.
Anyway, I think you could export the Table in CSV, and in Excel or similar interchange columns and rows. Then you could import the CSV file in a new Table.
