Custom Extension autorun and run in background
  • September 20, 2022
  • 0 views
I’ve created custom extension,
but my custom extension can’t automatically run and can’t run in background when my base opened,
is there any way to make my custom extension can autorun and run in background ?
Thanks
Forum|alt.badge.img+27
  • 6001 replies
  • September 21, 2022
No, it is not possible to have a custom extension run automatically in the background.
In order for a custom extension to run, it dashboard must be open.
If you want code to run automatically in the background, you can use a scripting action in an automation. If a script is too limiting, you can pair the action script with an outside service.
