Designing Custom Block using Chart JS, What is syntax to get column array data from table into data point
  • Jul 29, 2020 9:21 PM UTC
  • 56 views
Hi folks, I’m having alot of issues calling the records array that holds all the column data in my grid into my chart.js react file.
Currently I have a static array in my data field where I am manually entering inputs but I want the data field to be able to read directly from a specific column array so it will update dynamically?
Does anyone have any examples on how to have this done?
  • Jul 30, 2020 2:16 PM UTC
This may or may not be helpful. First, here’s a link to the simple chart index.js file.
Look at functions useRecords and getChartData.
Good luck!
