Does Airtable support any kind of two-way sync for Jira?
I’ve just started diving into Airtable and have successfully setup our Jira Cloud instance and synced the data into a base. This seems relatively useful, however not being able to update fields and sync them back is quite a big drawback.
Are there any workarounds to this? Is this feature anywhere on Airtable’s roadmap?
Forum|alt.badge.img+33
  • 8776 replies
  • June 14, 2022
Welcome to the community, @Scott_Richmond!
Airtable does not provide native two-way syncing for any of its features (not even for its own internal table syncing).
You could always custom-create your own two-way syncing using an advanced automation & integration tool like Make.com:
Note that building your own custom sync solution could take many hours of your time. Although I am not a Jira expert, I am both an Airtable expert and a Make.com expert.
So if you have a budget for your project and you’d like to hire an expert Airtable consultant to help you create this, please feel free to contact me through my website: Airtable consulting — ScottWorld
  • November 9, 2022
+1 a NATIVE 2-way sync with Airtable would be awesome!
Forum|alt.badge.img+8
+1 to 2-way syncing
