Formula error when dividing currency by integer of 2
  • February 20, 2016
  • 0 views
Formula error in inventory (imported cvs) when computing unit price.
COST column is specified as currency ($) and QTY column is integer 2 numeric.
U/PRICE column contains formula as follows: COST/QTY
(Result should be $ but displays as integer 2
Record from db is COST OF $1.00 divided by QTY OF 10 = U/PRICE BLANK INSTEAD OF $.10
THANKS
Best answer by Katherine_Duh
If the result should be dollars in the column, but instead it’s an integer, you should change the format to currency.
This is a formula where the output is set to integers, so in the last row, it rounds .10 down to 0.
But if you set the format to “Currency”—
Then it’ll work:
Does this help?
  • 332 replies
  • February 20, 2016
Then it’ll work:
Does this help?
