Help- Using for event & participant management & registration?
  • May 18, 2016 12:06 AM UTC
  • 107 views
Anyone know if this is possible or can do this?
We provide CPR classes to companies and individuals on certain dates and times.
Each class has a location, company, date, and participants attending associated with each class.
Current Airtable setup: One base
Tables:
Participants, Classes, Companies, Instructors, Campaigns.
Question 1: We have 15-30 different clients scheduling classes each month. How can I create a client “portal” so they can add their own participants in a class on their own without having excessive users?
Question 2: How can we offer online registration with online payment, and each person registering is added to the correct class?
Question 3: How can we allow instructors to access classes they are teaching so they can add and edit participants attending on their own?
Question 4: How can we print custom documents for mail merge purposes so we can print all participants from a class populated onto one printable document?
Question 5: How can we email all of those same participants at the same time?
  • May 18, 2016 1:57 PM UTC
It could be a good idea to work with a airtable consultant on your application , but I don’t know how to find one.
  • May 20, 2016 2:57 AM UTC
Check out the Work Offered discussion.
https://community.airtable.com/c/work-offered
Forum|alt.badge.img+15
  • May 25, 2020 1:14 PM UTC
I think our Client Portal extension can be the answer to this question.
Is it possible to know the technical solution (s) you have chosen because I have the same problem as you of how to choose the right and the best solution?
