How do i filter records with same tag inside the multiple tables ( within the same base )?
  • June 1, 2022
  • 63 views
Forum|alt.badge.img+13
How do i filter records with same tag (like status = ‘Active’ in a multi-select column) inside the multiple tables ( within the same base ) ?
I want to see the filtered records in another view maybe ?
Kamille_Parks11
Forum|alt.badge.img+27
If you had a “statuses” table you could convert each of those MultiSelect fields into Link Records fields.
Then you could use either apps or an Interface to view all the records from the relevant tables linked to the currently selected “Status”.
Hey ​@Jay_P!
It is natively not possible to do that. However, ​@Kamille_Parks11 workaround is a great/easy way to get around it.
Also, this might be a fun/easy use case with which to give Airtable’s native AI Assistant a shot.
If you get to try that out, please let me know your feedback!
