How to Connect Airtable as a DNS via ODBC connection
  • October 31, 2023
  • 10 views
I'm trying to push date from an Airtable base to a document managment software, NetDocuments, using the latter's native integration software, ndLink.
How do I set up an Airtable base as a ODBC DSN connection?
Best,
Harrison
wheeler500
  • November 2, 2023
Hi @HV67_2
To link Airtable to NetDocuments via ODBC DSN:
  1. Install Airtable's ODBC driver.
  2. Configure a new DSN in ODBC settings, entering Airtable details.
  3. Test the connection for accuracy.
  4. Integrate the DSN in NetDocuments using ndLink.
  5. Sync data from Airtable to NetDocuments.
I hope this will help you.
