How to create a field to add multiple records, eg "Add Work Experience"
Hi everyone and thanks in advance for your answers.
I would like to create a form that allows the user to add info through an additional pop up form, or something similar. I need to capture my users work experience and education and would like a secondary form to pop up with fields like “graduation year”, “institution” and “qualification obtained”, etc.
I would also like them to be able to add as many as they like/need rather than limiting them to a particular number. Below is an example of what I would like to do:
After clicking the “Add Work Experience” link, the following would expand:
I’m not sure if this is even possible in Airtable, but any help or advice would be greatly appreciated. Thanks again!
Natalie
Forum|alt.badge.img+33
  • 8860 replies
  • October 11, 2022
Welcome to the community, @Natalie_Creed!
Advanced forms like that are not natively possible in Airtable.
But you could build something like that in an external form tool like JotForm, MiniExtensions, or On2Air: Forms.
Upon form submission, your entries would populate Airtable. This is natively built into MiniExtensions & On2Air Forms, but if you use JotForm, you may need the help of an external automation tool like Make.com.
p.s. If your company has a budget & you need help setting this up, I am an expert Airtable consultant and you can reach out to me through my website! :slightly_smiling_face:
  • October 13, 2022
Thanks so much @ScottWorld, I’ll check out those options.
