How to randomly populate a column with values from single select
I have a base with a few thousand rows and I have a column that is single select type. Is there any way I can automatically populate that entire column with random values from the single select list (about 15 possible values stored there).
Forum|alt.badge.img+27
  • 6007 replies
  • September 8, 2021
This can be done with a script.
  • September 8, 2021
Would you mind sharing how to do that?
  • 6007 replies
  • September 8, 2021
if you know how to write code, the scripting documentation explains the Airtable specific concepts.
If you do not know how to write code, but are interested in learning, this is a good project to try once you know some of the basics of JavaScript.
If you do not write code and are not interested in learning how to code, you can try to find someone to write the script for you. There are several people on these forums who write scripts for hire, including myself. This would be a fairly easy script for someone experience at writing Airtable scripts.
  • September 9, 2021
Or for anyone else that’s interested, just use this: Apps - Airtable Marketplace
  • 6007 replies
  • September 9, 2021
Ooh thanks for posting. There are so many apps that it is hard to remember them all.
