iCal calendar view export issue?
  • October 26, 2022
  • 16 replies
  • 153 views
Anyone else having an issue with their shared calendar views? I’ve had a subscription to a calendar view in Fantastical for years that has worked fine, but it stopped functioning about two days ago. Tried deleting and re-adding it to Fantastical, but it says the calendar data isn’t value. Tried in MacOS Calendar too, and same error.
  • October 26, 2022
Unfortunately I have the same problem since yesterday. My subscription to the airtable calendar no longer works on google agenda, framagenda or thunderbird. The data no longer updates and if I delete the calendar to reinstall it, it is not recognized.
  • October 26, 2022
Be sure to open a support ticket with support@airtable.com about this, and post back here with what they say.
  • October 26, 2022
I received an email back from them with a pro-forma response saying they’re aware of the issue and working on a solution. So apparently it’s widespread. Thanks!
  • November 3, 2022
I am having the same issue. The issue first arose last week, and Air Table fixed it. Now it has happened again. Hoping for a quick fix. This needs to be reliable.
  • November 3, 2022
Same here - worked fine for a few days, now it’s happening again. Sheesh.
  • November 3, 2022
Agreed, please fix this! Not only is it not updating, it completely removes the events, so it’s just 100% broken. It’s eroding trust in your product, and we’re not paying to test the updates that get pushed out.
  • November 3, 2022
I totally agree 1,000% with your sentiments, but sadly & frustratingly, Airtable employees don’t interact with us here in the forums. It’s just your fellow Airtable users here. Be sure to send an email to support@airtable.com about this.
  • November 3, 2022
I know, another frustration :-). Mostly just venting; I did submit a report, and the vague form response from them doesn’t help. Hopefully this doesn’t keep happening.
  • November 4, 2022
I pushed a bit and a was told a fix will be in place on Monday.
  • November 8, 2022
Have you heard any update on this?
  • November 8, 2022
It seems to be fixed.
(for now)
  • November 21, 2022
Annnnnd it’s doing it again. This is getting REALLY old.
  • November 21, 2022
Yes, it broke for me as well.
broke for me as well !
  • November 22, 2022
I’m having the same issue.
  • November 22, 2022
Mine just started working again.
