Need Help Making IF formula, please!
  • Feb 25, 2021 2:24 AM UTC
  • 32 views
Hi there,
I would love your help with making an IF THEN formula.
I am importing my expenses from Mint. There are two columns:
  • Amount: $
  • Transaction Type: Credit or Debit
The amounts are all positive, and the “Credit” or “Debit” lets you know whether the number should be considered a positive or a negative number.
I would like to have the following statement turned into a formula:
In a new column called “True Amount” : If Transaction Type is Debit, Multiply Amount by -1
Therefore, if I spent $100 and earned $50 the numbers would look like this
-$100
$50
and sum to $50
Now they look like:
$100
$50
and sum to $150 which makes no sense
THANK YOU SO MUCH!
Kamille_Parks11
Forum|alt.badge.img+27
Try:
IF({Transaction Type} = "Debit", - {Amount}, {Amount})
