Not all table columns loaded to Power BI
  • December 30, 2021
  • 17 replies
  • 369 views
Only 57 out of 98 columns are loaded through the query HERE in Power BI. Does anyone know how can this be fixed?
  • March 8, 2022
I have the same issue! I’m using the M code provided by Airtable and it works fine, except that only about half of the fields are being captured. There seems to be no correlation to data type, column order, anything. It affects all bases. Any help would be appreciated!
  • March 9, 2022
Aha! After some testing I determined that the columns weren’t being imported because they contained no data. I had built the structure in Airtable but hadn’t populated it with much data, and once I had entered some input, the columns were available through Power Query. Hope that helps!
  • March 17, 2022
Thanks Sam for the feedback! in my case the columns I’m missing contains plenty of data.
Similar issue here. Columns with almost no data wheren’t being imported, since I populated the empty fields with dummy values they showed up in Power Query.
Forum|alt.badge.img+9
  • September 14, 2022
Same here, had this issue with Excel too. Tried different field types to see if there’s any pattern, but no luck.
So, do I need to populate empty fields with something in order for the column to be pulled through?
Yep, I suggest you populate each column with a “TEST” value or similar, and then in PQ you can filter it right out to ensure you’ve got the right data.
  • December 30, 2022
So according to airtable tutorial on how to load data on PowerBI here
"PowerBI will only load a field if the first record coming from Airtable has data in that field. So if the field is empty, then it won’t show up in Power BI."
This mean if the first record in the database has a field that is empty  that field wont showup, even if in later records that field has data.
Anyone know how to avoid this? besides creating the first record with fake data?
  • February 14, 2023
I'm wondering if there's a better solution than populating the first record with dummy text. This a big hiccup for the integration between Airtable and PowerBi. Any solutions?
  • May 9, 2023
Hi Everyone,
After some research + a lot of trial and error, here is a solution.
No need for dummy row or any other change at AT.
Replace this
 #"Expanded Record Fields" = Table.ExpandRecordColumn(
     #"Reordered Columns", "_airtableRecordFields",
     Record.FieldNames(#"Reordered Columns"{0}[_airtableRecordFields]),
     Record.FieldNames(#"Reordered Columns"{0}[_airtableRecordFields]))
in
With this
List.Distinct(List.Combine(List.Transform(List.Transform(Table.ToRecords(#"Reordered Columns"),each Record.Field(_,"_airtableRecordFields")), each Record.FieldNames(_)))),
List.Distinct(List.Combine(List.Transform(List.Transform(Table.ToRecords(#"Reordered Columns"),each Record.Field(_,"_airtableRecordFields")), each Record.FieldNames(_)))))
in
This solution iterates through all the records and merges the columns that appear in each record (then uses distinct).
Thanks to dofinity.com for sponsoring this.
Enjoy!
  • June 22, 2023
Thanks for your support, @Udi_Golan!
I'm now facing a different issue, however, so I couldn't try it. I'm trying to replace the API connection with a Personal token connection, but I'm getting an error related to credentials & authentication when I'm trying to fix this other error "We cannot convert the value null type to type Record"
  • June 22, 2023
Just a guess - due to the change you may experience also a permissions change which results with records not being returned and then null value instead.
  • June 29, 2023
Thanks for the reply, @Udi_Golan! I managed to fix the Token issue by updating the permissions, thanks!
I'm now trying your code replacement to show fields with empty values and it is still not working 😞
Is it as simple as replacing the code as you suggested? There's no need to replace other values?
Thanks
  • July 2, 2023
Thanks
As far as I remember there was no additional change required.
What is it that you get?
  • July 4, 2023
Hi @Udi_Golan. I got exactly the same columns that I was loading with the Query provided by Airtable. Columns whose first record values were empty, were not loaded to PowerBi after replacing the final part of the query according to your recommendation.
  • July 4, 2023
Hi @mario_lamban
Strange. The solution proposed is totally agnostic to the first record {0}
It runs over all records and extracts the distinct list of field names from all records.
Maybe the fields you expect to show on the BI are empty on all records and not just the first one?
Otherwise I would double check the code to ensure the code that includes the solution above is indeed running and not some other code.
Good luck.
  • July 10, 2023
Hi Everyone,
Replace this
in
With this
in
Enjoy!
Saved me, thanks a lot! 🙏
  • January 6, 2026
This still didn’t fix it for me. I’m still missing a bunch of columns.
nm, the column order was just wrong.
