Page Designer automation?
Is there a way to automatically generate and download/send a pdf of a page designer? Or has anyone found a way to do this with zapier or similar?
Our use case: We generate several reports a night which need to be sent to a distribution list. Right now an employee has to manually print as pdf and re-upload it to airtable โ€“ after that the automation sends it out. It would be amazing if we could skip that one last manual step.
  • December 9, 2018
I just sent a similar inquiry to Airtable support. I have a similar use case whereby I have a new record created via Zapier and would like Page Designer to autogenerate the pdf report and save it into a field under that same record. Then I could use the email integration to autosend the report with an email template to the corresponding record email address. How sweet would that beโ€ฆ
jowan_qupty
Forum|alt.badge.img+10
  • 25 replies
  • December 9, 2018
It is possible with Integromat:
Youโ€™d have to create the following scenario:
  1. receive trigger from Airtable
  2. create PDF of the data using the PDF module (This will take an HTML template and create a pdf out of it)
  3. send the pdf through gmail/mail module Or do anything else youโ€™d like (upload to Airtable/driveโ€ฆ)
  • December 31, 2018
Hi Jowan. Could you please elaborate a little more on this scenario? I had never heard of Integromat but it looks amazing. Iโ€™m trying to build a PDF from airtable uploaded media (photos). Do you have any good links for instructions on how to connect Airtable to produce PDF reports with Integromat?
Thanks
jowan_qupty
  • 25 replies
  • January 15, 2019
Thanks
Hi Pablo,
Apologies for the late reply.
Iโ€™m not aware of any online tutorials that show you how to automate this process but hope this can help.
Below is my Integromat Scenario which does the following:
  1. (Trigger: Using Airtable Module): You watch for a new record in a view.
  2. (Action: Using the PDF Module): You create a pdf using HTML (or plain text), therefore allowing you to bypass the page designer block until they release an API for it. This is a very helpful tool that will convert to HTML if you donโ€™t know HTML --> https://wordtohtml.net/
  3. (Action: Using the Google Drive Module) Ideally, we would directly upload that pdf straight to Airtable. However, since the previous PDF module can only spit out a url for the newly created pdf and not the actual file, then what I did was upload this url into Google drive, which you can then fetch as an actual attachment.
  4. (Action: Using the Airtable Module): You fetch the attachment from Google Drive, and upload it to wherever youโ€™d like in Airtable.
  5. From here itโ€™s really up to you. You can do whatever youโ€™d like. you can send the attachment by email, smsโ€ฆetc or automate anything else.
Hope this helps.
jowan_qupty wrote:
Hi Pablo,
Hope this helps.
Hi, apparently the PDF module isnโ€™t available in Integromat ? Any idea why ?
Forum|alt.badge.img+33
  • 8812 replies
  • May 24, 2020
Integromat disabled it due to security issues. Here are some other workarounds, using the Integromat platform: https://www.integromat.com/en/requests/requests-to-update-existing-apps/p/pdf
Note that you can also use the Formstack Documents Block (which is built into Airtable) to create PDF files as well, but that does require a paid Formstack Documents account.
Similar thing with this extension and a paid DocuPilot account.
  • 7 replies
  • August 5, 2020
Two new possible solutions.
Hi there! I believe that @Ben_Lillie solved the problem but still decided to share an idea that the job could be done using Zapier and Plumsail Documents. Maybe, someone else would find this useful.
I tried the app to generate reports based on Airtable data. For the case from the question, the Zap could be two-step - Airtable trigger, Plumsail Documents action launching the process of PDF generation. Inside the process, itโ€™s possible to set up various deliveries - sending by email as well.
Rupert_Hoffsch1
Just wanted to add DocsAutomator to this thread. It's a flexible and powerful solution to turn Airtable data into PDF + Google Docs and has been helping many Airtable users overcome Page Designer's limitations ๐Ÿ™‚
Forum|alt.badge.img+8
  • 68 replies
  • November 30, 2024
As an alternative, you can use typeflow.us. it will help you to generate PDFs based on Airtable data. We use Google Docs as template.
We offer a lifetime plan currently at 150$. This plan lets you generate as many pdf as needed.
